So far my Typhoon H has been a huge let down. I decided to go ahead and do the firmware update thinking it may resolve some of my smaller issues. I downloaded the new firmware version 2.10 off Yuneec's site and proceeded to update the H. Once the firmware update was done, I turned it off as instructed in the Yuneec Tutorial Video and then tried to power back on to see if the firmware took. That's when things went from bad to as bad as it can get. The Typhoon H won't boot up when you try to power it on. I get a single audible beep and I can see a series of blue flashing lights coming from inside the H and nothing. Thinking it may be a bad flight battery, I tried the new one I bought a couple of days after receiving the H. Inserted the new battery with a fresh charge into the H, pushed the power button and nothing but a single audible beep followed by nothing. It's bricked alright. No way to unbrick it that I can find since it won't power on at all.
Oh and a tip I figured out for folks experiencing the issue with the Video Record Button not working unless you press it a bunch of times. Go into the CHANNEL SETTINGS menu and locate the button labeled B4, press B4, Increase the curve settings, Save and exit the menu and try the button again, it should begin recording video with one simple press. Manage to figure that out before I bricked my H.
