Seems like a lot of work- To remove the loose foam so you can get the H out, and having to work the foam so you can get the H back in. I also noticed in the images that you have the props removed. With the MC-Case, you don't have to remove the props. The only thing is that you have to fold the arms down. There are other cases in the $500-600 range where the arms don't have to be folded down and the props still mounted when placing in the case. The foam insert that comes with the soft backpack is in a stacked form- you have to remove several components before you can get the H out. I like how every component has it's own spot and does not need 1 thing to be removed in order to remove another (except for the lower compartments- I put very infrequent components in those compartments.
Anyways, everyone has their own preferences, and budget. I really like my MC-Case, in terms of how my H stuff is packed up and the cost.
