I see plenty wrong with it.I will be attaching 4 and a half lbs. And programming it to fly 0.7 miles out and drop its payload and return back to me completely autonomously. Anyone see any concerns with my plan?
That may be true, in theory. However, the design of this aircraft and most others, includes the weight of the accessories that it would normally carry. When you exceed that weight you are placing additional stress on the motors and in particular the ESC's. There is a good chance they will overheat and perhaps fail in a short time.A multi rotor need 2 times it's weight in thrust in order to fly successfully. The H weighs about 1800 grams, so it needs 3600 grams of thrust for successful flight and manuver. Each motor generates approximate 900 grams, times 6 equals 5400 grams total lift. So, 5400 minus 3600 leaves 1800 grams of lift power. 4 pounds equals 1814 grams. So theoretically the H will not get off the ground, it would meet to generate over 7200 grams of lift which the airframe will not support. Good luck.
Where did you see this? The takeoff weight is listed as 1965g.@Steve Carr everything I read says that it has a payload capability of around 2500g. Is this untrue? I've watched video of it carrying two water bottles with no issues... Am I missing something? I'm new to the hobby so help me out here please.
The drop area has to be under surveillance of the pilot or a ground observer in communication with the pilot.They do, but that requirement might be satisfied with V/O, assuming, of course, the aircraft was still visible to the naked eye of the operator..
