I'm talking hand held aircraft radios. If broadcasting from the ground communicating with a tower is range limited. They are better from the air.
There are handheld ham radios.
I used one all the time to communicate with other hang gliders when I use to hang glide.
I have a HAM radio but it does not TX/RX Aviation Frequencies.Are you talking just aircraft radio or ham band radio ?
I'm probably wrong, but I'm thinking you cannot transmit in the aircraft band without being a Part 107 UAS Remote Pilot under the FCC Special Rule for pilots. Who knows for certain about that? Ham license will not do.
That would be a good guess but you can listen and learn the lingo, but I have been listening to boise airport and they so fast LOL cant catch much
5 Watts is a fair amount of power.Most handheld ham radios do not all TX on AM just recv.. The Icom is a good choice
Icom IC-A14 COM Aviation Radio not allot of power
In the UK listening to Airband traffic can be an offence, I know in HAM radios in the US you need an FCC license to broadcast but not to listen. I'm not clear on the requirements for airband TX on the ground without a ground station license in the US, but looks like there are some special use clauses that might be a work around.I'm probably wrong, but I'm thinking you cannot transmit in the aircraft band without being a Part 107 UAS Remote Pilot under the FCC Special Rule for pilots. Who knows for certain about that? Ham license will not do.
Sorry I read it wrong I thought is was 1.5 watt5 Watts is a fair amount of power.
