Folks,
If you have been using your H for a while, you may have noticed that the battery doesnt always seem to seat fully at times, what the heck?
Well you may need to do a bit of surgery.
Eventually over time, the front sonar board foam insulation that seats around the outside of the board and right below the battery, becomes fatigued.
It will then interfere with a good battery to H connection, which is bad.
To remedy this, take your battery out, shove a light up the H's butt and inspect for any obstructions. If the sonar board foam is in the way, you will need to cut it out if there.
Good Luck.
Good Luck.
