Breeze lights and camera feature
In the manual there are infos about blinking lights on the Breeze but I presum these are lights on the switch button, right ? But what about info about light which is on the left motor arm ? There is a white, green and red light. is there info about those lights somewhere.
About camera settings, couple of things.
- is it possible to use camera without powering motors and flying
- where to change camera settings
Thaks for the manual but I already read it. I haven't founf anything about lights in the motor arm, only switch button lights. Or maybe I don't understand something ?
For the camera usage without motors, if I understand correctly , I need to take off and land to have ability to use camera without flying, right ?
My personal observation is the lights are related to the wifi connection.
Flashing red - initializing the wifi connection.
Flashing green - wifi ready for connection.
White - wifi connected.
Or something like that?
There's also an undocumented reset button next to the Micro USB Port.
Even the FPV controller takes a special command to connect to Bluetooth.
Again, undocumented.
You'll find both these issues explained in other threads.
Yuneec could have done a better job on the documentation for this bird.
drakemerch33
