I asked a pilot I know he said don't waste your money. The H will be working flat out to get off the ground and battery life will be virtually zero. In addition low battery warnings will likely come to late for you.You will need to call Yuneec to get the firmware to fly above 8000 feet. They also suggest using the after market carbon Maytech 13x4.5 CF Props for the Q500. Not sure who has them in stock.
Even with that being said you will have to be a good pilot as the air is very thin that high up and controlling the Q500 will be a challenge for sure.
Sent from my SM-N9005 using Tapatalk
