CG02+ CAMERA QUESTION
I have completed the firmware updates on the transmitter, drone and the camera. My problem is that I cannot switch the video mode to anything but 50 fps. No matter want I select under camera settings on the st10+ transmitter it stays on 50 fps. Don't know what to do.
sj, try disconnecting the battery from the controller for a few minutes and then reconnect.... I assume through the GUI you then have verified you have all the latest firmware downloaded...Was everything working fine before the updates...if yes then I would try installing the updates again...good luck and let us know how you make out
mathewthomasmt
