R
OK for very limited use. Needs to be at least double the resolution for me to consider it. Thanks for posting. Its the first video I've seen of the ET showing test performance in actual flight.
Good luck with that. The latest FLIR camera announced at CES has a LOWER resolution than the CGO-ET. The FLIR cameras that are higher resolution seem to cost twice as much as the CGO-ET. What's your use case?
My use is varied. Knowing that I am looking at an immobile human from 200ft would be a start. Of course that would involve better radiant resolution and more pixels and higher cost. Not complaining, it is probably the best integrated system for the price.....just not for me.
Why?? I want to definitively say there is a human from 200ft minimum above.
What I mean is, just because it's low resolution doesn't mean you cannot pick up a heat signature. And any heat signature is pretty likely to be a human - unless you're flying above a herd of cows
on FLIR's website today, the VUE is 336x256 for $1499.Good luck with that. The latest FLIR camera announced at CES has a LOWER resolution than the CGO-ET. The FLIR cameras that are higher resolution seem to cost twice as much as the CGO-ET. What's your use case?
