CGO3 MPU Wiring Diagram
Alabama
During the process of replacing the lens and housing on the CGO3 with a 4:35 mm lens, the four wires on the MPU disconnected. These wires are not color coded. I thought they were resoldered in the correct position. Apparently they are not. When I turn on the Camera is beeps and there is no gimble movement. The camera turns on and I can see a picture on the st10 but there are vertical lines in the same. Does any one have the wiring diagram for connecting the wires to the MPU and how to tell which wire goes where. Photo attached shows the wires after they were resoldered but in the incorrect position.
Jesster0430
