CGO3+ wiring problem and question
Has anyone crashed and had to re-wire the small circuit board w the new Typhoon H CGO3+ camera?? I soldered a few back but cannot tell where the red wire went. Any help is appreciated! ThanksIMG_3324.JPGIMG_3325.JPG
Reactions: Tomki04
so Jon, how did it go? I have the same problem. unfortunately, the wires were pulled off from the solder. So there's no way tracing which color is to which.I tried to copy what you did there but it seems it's not working.... Can you guide me to which colors is to which? thanks.
Thanks Erikt. So basically, Jon's wiring is correct except for the red wire which should be with the blue. right?
Thanks Erikt. I finally got the gimbal working. Unfortunately, It only works for the steady grip. I cant control the pan and tilt through st16... Figured that im not getting any supply from the drone port. see attached pic... the white one with K value is a fuse and is busted so i jumped that fuse and the gimbal works but still doesnt pan or tilt from the controller.
Hey there, i hawe same problem,i crashed the drone and the wires get out,and i solded them back,but i cant cotroll pan and tilt in controller st16.The gimbal itself its working fine.
Got any news about it ?
-Mika-
I wired mine back and nothing is working still no power to camera any ideas ?
I too am working to fix this. The white wire seems to have came loose in this swivel connection. Can anyone tell me how to remove this metal sleeve ?
Sent from my iPad using Tapatalk
Ok. I managed to remove the sleeve and the way the wires ripped out, I need this part. Anyone know how or where to locate just this part?
hate to say but you will not be able to get those parts. not even from Yuneec. its a total lose
Does the crash kit not have that piece included?
I just had this happen to me and I ordered that kit. $66 off amazon. Shows it comes with the connection board
OK nice to know. It wasn't available when I needed it. Yuneec repaired for a total of $53. However, doesn't matter now as I had a fly away and no longer with the drone. Guess I'll need to get another to start back up.
How did you get the sleeve off?
I have same problem. After crash I bought a new camera and there´s no power to camera. Is there somekind fuse on the main board or is the main board broken?
Sorry my bad english but I am silly finnish :)
atas77my
