It should be specified by the manufacturer.
USB 1.1 and 2.0 were specified as supplying 0.5A maximum. USB 3.0 can supply 0.9A, so the 1A rating of the ports on the Deltaco is above spec, but unlikely to cause any problems.
If your powerbank can charge an iPad (and I suspect it can), then it must actually supply quite a bit more current, since that requires 2.1A. My Adata also supplies 2.1A. I do not know what the port on the Yuneec charger puts out, but when I get home I will conduct a quick test and see if it will charge my iPad -- if it does, it must supply at least 2.1A, in which case the concern about keeping the charge rate below 1.5A is moot.
