  1. Tim Orourke
    After calibrating compass on 2 H's I need to recycle H to reconnect with S-16.
    Anyone else have this happen?
    Tim
  2. Steve Carr
    Steve Carr Moderator
    Staff Member
    Bessemer, MI
    After any calibration the H should be power cycled.
    QuadBart likes this.
  3. Tim Orourke
    OK that I did not see in manual
    Tim
  4. Steve Carr
    Staff Member
    Bessemer, MI
    It may not be in the manual Tim. I just know from experience.
    QuadBart and JohnL like this.
  5. Tim Orourke
    Just being causes my first H died after a few short flights. Bring this one on line slowly
    Tim
  6. Steve Carr
    Staff Member
    Bessemer, MI
    Sorry Tim, but I don't understand your post. Can you explain?
  7. JTorsrud
    It is also beneficial to remove your Camera before calibrating the Compass. That way you don't risk damaging the Gimbal.
    That's what I do and it makes calibrating easier.
  8. WheelsUp
    +1
  9. abinder
    I would think that if its hard on the gimbal, Yuneec would say something about it and they wouldn't have the videos showing the calibration with the gimbal installed.
    Is there a way to temporarily disable the gimbal ?
  10. JTorsrud
    Unfortunately, Yuneec does not always tell you everything! I'm just saying it is easier to rotate and calibrate the compass without the Gimbal and Camera attached. With the camera and gimbal being flipped around and you only have 30 seconds to get it done, removing the gimbal and camera makes it easy. Plus, I don't think the stress on the gimbal flipping around is a good idea! And you don't have to calibrate the compass every time you fly. I know some people that do that.
  11. abinder
    Why would it be "easier to rotate and calibrate the compass without the Gimbal and Camera attached" ????????
    I calibrate the compass every time; better safe than sorry.
  12. JTorsrud
    Try it sometime. The Gimbal and Camera come off very easily.
    When twisting the machine thru the calibration process, you are putting stress on the Gimbal that it would not happen under a normal load. Since you have to do the calibration quite quickly to keep within the 30 second time frame, this works well for me.
    I calibrate my compass if I travel more than 40 miles from my home site. Most of my flying is done right at home. No need to calibrate everytime!
  13. banned user
    It's not a good idea to calibrate your compass without the gimbal, you should calibrate it exactly as it will fly, if you wanted to be even more pedantic about it, you should calibrate it with the memory card in the camera.
    Any new ferro metallic part's that you add to the H after the calibration i.e. anything which is magnetically attractive in the camera will skew the compass values. How much depends on how close to the compass and how much ferro metallic parts you add.
    abinder likes this.
  14. JTorsrud
    The small amount of metal that is in the Gimbal and Camera is insignificant when it comes to the compass. And besides, here is what YUNEEC just sent me:
    Update for Case 8530 - "Compass Calibration without Gimbal"
    Hello Jeff,
    Yes, it is fine to remove the gimbal and camera to calibrate the compass on the Typhoon H.
    Glad I could help!
    Regards,
    Brandon Shelton
    Customer Care | Yuneec USA Inc.
    5555 Ontario Mills Parkway
    Ontario, CA 91764
    T: 909-259-5113
    www.yuneec.com
  15. banned user
    interesting,
    I would not have thought that the amount of ferro magnetic metal in the gimbal motors is by any means insignificant, however your email goes to show that the documented calibration procedure can be broken....edit - although I would not advise it
    #15 banned user, Jul 22, 2016
  16. abinder
    I've been thinking about the "keep within the 30 second time frame".
    Where does it say you have only 30 seconds to calibrate the compass of the Typhoon H ?
    Only place I saw anything about only having 30 seconds to calibrate is the video for the calibration of the wizard.
  17. JTorsrud
  18. abinder
    Are you sure it just doesn't 'time out' if it doesn't sense any movement of the Typhoon H ? Next time I'm out, I'll try to remember and extra slow doing the compass calibration.
    (It's very possible the 55 seconds you saw is just a 55 second time out if no movement is sensed.)
  19. abinder
    I never disputed your claim about removing the gimbal and Yuneec support saying it was okay.
    (I don't think anyone said that Yuneec didn't say that to you.)
    I don't know why you're bringing it up again.
