  1. Gary Miller
    Highland Twp, Michigan
    How do I copy files from my PC to the ST16. I have created a flight from CCC editor and need to copy to the ST16. I tried connecting my PC to the ST16 to see if my pc would recognize it as a drive but it didn't work. Any suggestions? Thanks.
  2. wedbster
    To access from your PC to your ST16 power on your ST16.
    Or you use a Micro-SD-Card for the file transfer, formatted FAT32 insert into the bottom side of your ST16.
    ccc-file - > Internal storage\flightmode\mission_data
    [​IMG]
  3. Gary Miller
    Do you access the file on the PC from the ST16 file manager or does the PC recognize the ST16 as an external drive and you copy to the ST16.
  4. wedbster
    The ST16 has no access to the pc, but the PC get access to the ST16, when you power on the ST16.
  5. Gary Miller
    Thanks. I tried connecting it but it was powered on when I connected it. I will try to connect and then power on. I appreciate the help
