Curved Cable Cam Speed
An entry on other forum explains CCC speed concisely, but I hadn't been able to make it work, at least not consistently.
Curve Cable Cam speed
"After you set your waypoints try these steps.
1. once you get to your 1st point and push the left stick forward (away from you ) to get it started on its path it always seems to go 10-11mph in that direction .
2. Now if you want to slow it down tap the left stick back (toward you) Very Very quickly ALL the way back and letting the stick return to the middle without pausing.
Each time you do this it will slow down about 1 to 2 mph intervals. Keep doing this until you achieve your desired speed."
This may be obvious or covered in another thread, but I believe the above works for me only if the right slider is in slow (turtle) mode. If in fast (rabbit) mode it appears to slow to half speed (5mph) with one pull back on the stick and total stop with a second.
If anyone has more info on this and/or I'm in error, please let me know.
Sierrarhodesss
