Dashware vs Typhoon H logfiles
Denmark
Hi !
I have been battling issues with the use of Typhoon H logfiles, up against Dashware, and have (almost) given up.
I have been watching Youtube and read numerous forums, but all is connected with the Q500 and does´t work properly.
I have installed ST2Dash, tried converting the logfile (with st2dash), I have installed a specific Datafile for Q500 and even a costum template for the Dashware....but it only works "partially" and the data presented, is not correct (e.g. Altitude=1 and speed dosn´t match actual speed aso.)
Does ANYBODY know how to get this to work, files and links would be MOST appreciated, please ...no more Q500+, I think I have tried every combination possible.
-Which logfile changes need to be done (is st2dash the correct tool)
-Which data profile must be used (Which are crusial)
Anyone´s got experience with Dashware and Typhoon H (pro?) and can help ??
Tnx. guys!
Best wishes from Denmark
Hi Wedbster
I´ll try this, tnx. !!
I´ll let you know if it works for me.
Best regards
Some people also have trouble with the newer data file. If you still have problems try the older data file I have attached.
  • Yuneec Q500 v1.4.zip
mathewthomasmt
