Disassemble Stephanie!
Thanks for posting this video it helps a lot
Reactions: Brian Mackey
All those bullet connectors, 18 failure points. I took mine off and soldered directly to the board. I have had bullet connectors fail in the past and have heard of many builders shy away from them.
Thanks for posting.
I have had one bullet connector fail in one of my home built drones. I have also had solder joints fail from the factory, not my soldering.
I have removed bullet connectors in the past to reduce weight.
VertCold22
