PatR
Premium Pilot
Compass calibration is essential to accurate and stable flight with any system that uses a compass. This becomes even more critical during periods where GPS is not available. The system maintains orientation not via GPS, but from compass alignment and offsets from due north. GPS is more concerned with a ground reference position, not aircraft orientation. Our camera drone systems use three basic references for position and orientation, a pressure barometer, a compass, and GPS. Take any one of the three out of the mix, or fail to calibrate them correctly, and positional accuracy is tossed out the window. You'll get what you get and hope for the best, which won't be as much as it could have been.
Don't be scared, calibrating the compass is not difficult. Yes, it has to be done fairly quickly but look at the bright side; you're not calibration an octo or dodecacopter, or a system that also needs to be rotated in the vertical plane. You are also calibrating a pretty small aircraft so it's easy to handle. Yuneec uses the same calibration method on the rest of their stuff. Just an FYI, another system experienced quite a few fly away's awhile back due to conflicts between the compass and GPS systems. Nobody wants a fly away so what's the problem with performing the task that helps eliminate them? People manage to come up with a great many reasons not to do something but when things go wrong they are quick to blame a product where the users failed to perform system alignment accuracy tasks that are their responsibility to execute before the first flight.
