Encountered problem share after new firmware updated
Goh
After new firmware updated my ST16 out of control, the gambal tilt control slider and both height slider became motor on off switch(the ref button switch totally on response) and once the H and the ST16 connected motor auto start because of the slider and was unable to stop the motor needs to pull out the battery this even repeating install the firmware also unable to solve the problems, finally I decided to factory reset the ST16 and rebind the H and the ST16 the problem solved
Must have been corrupted when uploading/downloading? Have any malware on your PC that could have attached itself to the file? Many possibilities, glad you cleared it up !
Reactions: Goh
The PC is well protected, but now is ok and after FW update the video is improved
Reactions: DroneClone
Bech
