esc assignment problems
Hi all, i was wondering if anyone has experienced this problem with a Q500 4k.
I have rebuilt after a crash. When i plug the drone into the gui it says my no2 esc has falied even though this esc was replaced. When i try to assign i start at 1 (as per gui) then i can get to number 4 and it fails to assisgn 4. The strange thing is, if i reassign and start 4 as 1 i can assign all the motors. And they all show green and spin in the correct direction and show no errors in the gui.
The problem is, it appears the motors are now not assigned to qtheir correct position and the drone won't lift off without wobbling erratically and crashing.
As a result of no technician having a clue whats wrong i was recommended changing out the main board, which i did.problem is still there.
Anyone with any thoughts on the matter?
I have learned you need to turn them in the right direction as fast as you can, within 30 for all four for it to correctly connect, hope this helps.
csandoval
