Firmware update
Hi guys quick question have just done the latest firmware update everything went fine, did calibrations all ok. One question forgot to clear flight data is this a problem?
I think general consensus is that clearing flight data is really for when the ST16 has an update (so this update it's potentially not necessary), however Yuneec have still linked to the video which says to clear flight data so there is no harm in doing it. Basically, seems to be no right or wrong answer in this case....
Just been for a quick flight seems fine but will clear flight data and recalibrate. Thanks for your help.
Once you clear the flight data you will have to create a new model, select the CGO3 Pro camera and rebind.
OK thanks
When you get ready to launch watch the GPS coords on the ST16 and make certain they have stabilized before you take off. The stored coords may have been erased so it could take a bit longer to get a good fix.
drakemerch33
