Flight-log
Discussion in 'Q500 4K Discussion' started by Anchieta Filho, Jan 2, 2016.
  1. Anchieta Filho
    Hello, I wonder if a flight in telemetry, writes corrdenadas where the photo was taken.
    If so, to which flight log file will find.
    Thanks,
  2. wedbster
    Hi,
    if you use a SD-Card in your ST10 then you can find three different logfiles.
    In two of them, you will find gps coordinates.
    Look in the RemoteGPS-Folder to use the easier file.
    You can open the file with open office for example as spreadsheet.
    Then you have on the left side the date, following with the gps data
    Look for the date/time of your photo
    [​IMG]
    Anchieta Filho likes this.
  3. Anchieta Filho
    Thanks for the answer,
    But I can not tabulate that way.
    In my spreadsheet opens the way it is attached.
  4. Fleamac
    West Michigan
    Take a look at this. Maybe it'll help. You can also overlay the telemetry onto a Google Earth map, or overlay the data on the video through Dashware. Idk if this help, hope so. They're so much to learn with these birds.
    Deciphering telemetry files
  5. wedbster
    If you use Open Office Calc you only have to "drag&drop" the csv-File.
    A box pop up and aks how to import your file.
    Select: separated by commas
    In the infowindow you can see what happen to your selection
    You can use both date - latitude + longitude - and ask google where this is.
    .................google.de/search?q=53.07518 7.8968587
    [​IMG]
    #5 wedbster, Jan 2, 2016
  6. FlyboyFunk
    Pedweld likes this.
