FLY WITHOUT GPS AND RETURN TO HOME BACK USE GPS ON
Just want to know..
if we fly first with gps on at 500Att and distance 800feet and i want to off gps from st10+ for fast movement (in situation you dont see your drone) if that posible. And after that you select to return home back use gps on back.. :confused:
i don't think ( almost positive ) you can turn off the GPS from the ST 10 while in the air only before you start . with the H and the ST 16 transmitter you can start and stop GPS transmission from and to the H .
Sierrarhodesss
