- Joined
- Apr 28, 2016
- Messages
- 25
- Reaction score
- 3
- Age
- 70
I've not flown while its been actually snowing, but have just after snow has fallen. I see a snow fall as precipitation which should be avoided if at all possible...but that's just me.Curious, has anyone tried flying when it's snowing out and what would be some of the problems?
Here in England the temperature doesn't often get down to 25f during the day time at lower levels so our snow does tend to be a bit more sticky. Further, the air also tends to be damp during snowfall too. (We don't get snow like we used to, say, 50 years ago)Depending on the temperature falling snow is quite dry. Below ~25*F there is virtually no threat of moisture unless the snow melts. However, at 25F or so snow is not "sticky" and just bounces off objects of equal or lower temperature. I've flown many times with an H or Chroma in light to medium snowfall but limited the time of exposure for two reasons. One; to minimize the amount of potential snow melt on the top of the aircraft, and two; because I was freezing my a$$ off. I will not fly during snowfall with an aircraft having uncovered electronics.
Pay close attention to battery voltage when it's cold. They do not provide nearly as much flight time.
Use Corrosion X
WD40 works too, but this stuff Corrosion X, you can actually lose your H in the water, recover it and fly it with no damage to any of the electronics. In fact, if you water proofed it correctly you could fly it underwater.I just wiped wd40 on mine and went flying lol
