  1. Photo
    Hi, anyone who can guess or know how long time you can fly with a tethered H w/o overheating the motors or anything else in the drone. Let's say you fly in 25C / 77F.
  2. Rayray
    Rayray Moderator
    Staff Member
    Pine Forests of Deep East Texas
    I doubt the tether would matter as long as it is not a log chain.:)
  3. Photo
    Guess you mean long chain? But the load of the chain will probably compensate by the less weight of the smaller battery? So one can fly "forever"?
  4. Rayray
    Rayray Moderator
    Staff Member
    I misunderstood. Did not know you meant a powered tether w/o using a battery. My bad.
    I have no idea, if it is a commercial setup, the manufacturer should be able to advise.
  5. Photo
    Ok, here is info and I doubt Yneec will tell how long you can fly before it breaks or the motors will burn!
    Hoverfly Tethered Yuneec Typhoon H
  6. Rayray
    Rayray Moderator
    Staff Member
    So this is what you are talking about?
  7. PatR
    Home in May
    Put a thermocouple on a couple of ESC's and motors to baseline the temps. Run thermocouples up to the system to monitor temps. When you observe a delta large enough to generate concerns, land. When there's no reference data you have to develop your own.
