Gimbal is broke. Can i still see video on transmitter?
New to this. Gimbal is broken, wires arent connected....Can I still use wifi on GoPro 3 to send video to transmiter?
thanks
No its different. GoPro wifi is 2.4 Ghz and the ST10+ receives 5.8 Ghz digital. Its not recommended either using the gopro wifi as it could interfere with the ST10+'s 2.8 Ghz connection to the Typhoon control.
Reactions: Russell Smith
What got disconnected on your gimbal? Just the short patch cord to the Typhoon or is it the one going to the MK58?
You really don't need those three wires as you can just use the supplied patch cord and it does the same thing.
Or if you want to resolder the wires here is a very good way to make it even better for the next crash. The instructions are for the CGO3 gimbal board but its the same procedure for the GoPro board.
C-GO3 - Broken Gimbal wire repair - pre-emptive modification
drakemerch33
