  1. Black Dragon
    I think it's time for yuneec to upgrade the quality of the gimbal slide system
    The rail system is flimsy. ...... mine just cracked and fell off. They're supposed to be sending me a new one....... EVENTUALLY !!
  2. raymond captuo
    remsenburg ny 11960
    mine cracked and fell off too while in the air....now my camera is f...d up....i heard that they did improve it a bit....don't know where i saw that....rails are supposed to be a lil thicker
  3. TopFlightTexas
    Looks like RMA is the flight path of choice . . .
    #3 TopFlightTexas, Jul 15, 2016
  4. Jimmylee
    The camera mounting rail is very fragile and care needs to be taken
    when removing or installing as not to break it.
    I am sure this is by design to make this part the weak link and the
    first part to fail in the event of a crash or hard landing.
    This will probably save the gimbal / camera and wiring from being damaged.
    If your familiar with DGI drones the gimbal and camera are the first to be damaged
    in a crash because the weakest link is the gimbal itself.
    I think the Yuneec is the better design.
    Anybody else agree on this theory?
  5. raymond captuo
    remsenburg ny 11960
    yes i agree it is a much better design then DJI....but mine came broken and didn't notice it until it was too late....so now dealing with yuneec cs is a challenge....
  6. Jimmylee
    I think they should probably ship them with the camera not attached.
    UPS handling can be worse than a crash. LOL
    WilsonFlyer likes this.
  7. glider
    I know first hand the gimbal is made better on the Yuneec :(
    When mine crashed, it flipped end over end, pulled two of the dampeners out and broke one of the pin locks. The camera/gimbal was dangling and I figured it was a goner, but after fixing everything it seems to work fine.
    Now I just wish I could get the camera focus sharp. It looks like a new lens is the only option.
  8. Black Dragon
    It's a great gimbal...... the way it attache's to the H is also great..... the quality of the part needs improvement
  9. Forrestt
    North Carolina
    Just had a thought. Why don't we design a lanyard of sorts for added safety.
  10. Forrestt
    North Carolina
    A small loosely attached nylon zip tie would probably do the trick. Cheap, easy to replace.
  11. CAPTAINDRONE
    Ottawa, Canada
    I'd say it's designed to easily break off to save the $500 camera which in my opinion is a good design. I think if I had to order the part due to it breaking off once, I'd probably order two as it's likely to happen again.
    Regarding DJI and the Phantom. The Phantom 2 & 3 would have expensive damage to the gimbal/camera in a crash. The Phantom 4 has an internal gimbal and the number of reports of damaged gimbal/camera in a crash are much less than before.
  12. Jimmylee
    If you have a 3D printer I have a 3D STL file of the Typhoon H gimbal mount if needed.
    Have not printed it out yet as I have not needed it.
    Haydn likes this.
  13. Jimmylee
    Are you familiar with 3D printers jngrally?
    There is no good answer to that question because you control
    all the variables when 3D printing.
    Most parts like Yuneec's are plastic form molded parts.
    I have found 3D parts can be as good or better but not always.
    Type of plastic, ABS and PLA are most common, ABS is stronger,
    PLA more flexible, Rubberized plastics also available like Ninja flex
    that I have used.
    Then there are the variables for the print job like,
    Extrusion width, layers, infill, additions, supports and more.
    Bottom line is you can make the part as strong, weak or as flexible as you want.
  14. Paladin
    Pittsburgh
    It is funny that I stumbled across this post, I have been looking at 3D printers on and off, been wanting one for years but they were too expensive. They came down a lot in price depending on what you want etc... Just would be fun to play with. Do some work with it maybe.
    I want one that can do ABS and PLA. Maybe some other materials. I was looking at the Flashforge Finder but that is PLA only.
    A cheap one that may be fun to play with is the XYZprinting da Vinci 1.0
    The main one I think I have it down to is the FlashForge 3D Printer Creator Pro if I want to go that high. Seems the best bang for the buck.
    I dislike the maker bots etc.. too propriety in parts and supplies etc... Way over hyped. I want something that can use off the shelf supplies.
    Some of the DYI ones look very cool but I am unsure I would have the patience to put them together. Unsure which is the best etc... If you have any input, I would like to hear it. i:)i
    Please PM me the file in case I get one, it would be a good test. i:)i
  15. Jimmylee
    Paladin the XYZ Da Vinci 1.0 is the printer I have had for about two years now.
    It did use proprietary plastic cartridge when I first got it but updated the firmware with Repetier software to eliminate that.
    I have upgraded the print head and many other parts on it to handle the different plastics.
    There are hundreds of 3D printers to choose from so good luck.
    There are also many 3D printer forums out there as this is not the place to discuss them.
  16. Paladin
    Pittsburgh
    It was just conversation man. I was not going to start an entire thread about it. Just a small sidetrack
    They don't charge by the byte here so.... i:)i
    Anyway the Da Vinci may be he way to go for me due to its low cost. I will try to find some information on how to upgrade it etc.. You seem to like yours. i:)i
    I will say no more about it. i:)i
    I would still like the file though please. i:)i
    #16 Paladin, Jul 17, 2016
  17. Mickeyboo
    Madison, WI
    Can you send me the 3D SDL file for H gimbal photo4u@michaelkienitz.com
  18. Jimmylee
    It was not you I was worried about, I get carried away and hijack threads sometime. :rolleyes:
  19. Jimmylee
    Tried sending you the STL file but getting error.
    Is that your email link?
  20. Jimmylee
    Is there a way to upload this STL file here for people to download?
