GPS Tracker advise
Discussion in 'Q500+ Discussion' started by Viking233, Aug 27, 2016.
  1. Viking233
    New Jersey and New Hampshire
    it seems like good idea to have a tracker on the Q-500 in the event of a fly away. Does anyone have a recommendation. I've studied this and it's all over the place to include units that are counterfeit . Then you find a tracker with a few hundred reviews with very convoluted answers. You'll get 100 people that rate as 5 star then there 20 that hate the item. Saying horrible instructions, last 2 days, difficult to understand yet others write easy of operation. So the only place to get good info is in here.
  2. louisiana Drone Boy
    I have the
  3. DroneClone
    Texas
    Marco Polo or Trackmo's are the two main ones you can look at!:rolleyes:
  4. louisiana Drone Boy
    Tk102b a good one also..all you need is a sims card
  5. GRH
    GRH
    Demunseed did a video review on the Marko Polo Tracking system earlier this year. Up to two miles tracking range LOS. Looks simple to use. I just received mine from acesdeals.biz but havn't tried it out yet.
  6. Viking233
    Thanks guys for your input . They seem light enough, only like 1.5 oz.
  7. davidnclearlaketx
    Clear Lake TX
    I've had great luck with the drone-mods UAV locator. When not using on the Q I put it in my older vehicle in case of my SUV getting stolen. Works perfect even inside a garage inside the car.
    Drone Mods UAV Locator
    INFO:
    Features
    * Standalone device powered by a rechargeable lithium-ion 1300 mAh battery that will last up to 12 days.
    * Compact and lightweight; the device measures 2.6" L x 1.45" W x .75" H (67mm x 37mm x 20mm) and weighs only 53 grams.
    * 6 months of service included for free!
    * Carrier agnostic. Not forced to rely on a single carrier's network. Triangulates position using all available networks in the area.
    * Includes a specialized SIM card that utilizes network hopping to ensure GPS coordinates can be retrieved 99% of the time.
    * Two low-cost service plan options to keep your device activated after your free service period expires.
    * SOS button for sending GPS coordinates on-demand. Useful if someone else finds your UAV before you do.
    * Uses high sensitivity GPS and assisted GPS and operates on the GPRS/GSM network; accuracy range of 3 ft. to 150 ft.
    * Thoroughly beta tested by volunteers on a number of popular UAV's: AR.Drone, RC Eye 450, DJI Phantom 1/2/3, Phantom Vision/Vision+, DJI F450, DJI S1000
    * Very reliable even in rural or densely populated areas.
    * Will not interfere with your UAV's onboard GPS systems.
    * U.S. based phone number.
    * Crash proof, non-magnetic, water resistant case.
    * Two low-cost service plan options to keep your device activated after your 6 months of service expires.
    * 1-year manufacturer's warranty
    * FCC and CE certified device; RoHS compliant
    The Drone Mods UAV Locator was featured in episode 2 of the Multirotor Magazine podcast. CLICK HERE to listen to the segment.
    How it works
    The Drone Mods UAV Locator is a small, lightweight, self-powered, standalone device that attaches to your UAV. If at anytime you need to retrieve the location of
    your UAV, simply call the phone number assigned to your device. Within 15-60 seconds you will receive a text message and an email containing a Google Maps
    link with the GPS (latitude/longitude) coordinates of the device. View an example of what you will see in Google Maps. A green arrow pinpoints the location of
    your UAV on the map. Go to this location and look around for your UAV. Search within a range of 3ft to 150ft from the green arrow. The distance can vary by
    how obstructed your UAV might be.
    What makes the Drone Mods UAV Locator different than other GPS trackers?
    Our device was specifically designed for locating and retrieving unmanned aerial vehicles in the event of a loss or fly-away. The SIM card used in the Drone Mods
    UAV Locator does not rely on a single carrier's network. It utilizes all the networks available in the area to triangulate your UAV's position, much the same way the
    police and fire departments do when you call 911. This means you can count on getting an accurate location every time you fly. Other devices can't offer the same
    dependability and reliability the Drone Mods UAV Locator can.
  8. Gogittum
    My Q500+ flew out 300 ft a few weeks ago, then stopped answering the controls. It paused for about 20 seconds, then dropped straight down into a very rugged canyon with props still turning.
    I failed to find it with an intensive search, so went home and put the SD card from the ST10+ in my computer and went to telemetry. That wasn't working right (I've since de-bugged it to where it now gives full tracks of flights) but did give me a single location that plotted out on Google Earth to be about 300 ft from where I'd been standing.
    Next day I entered that location into my GPS and it took me right to my drone. Phew ! ! ! Up till that point I'd been thinking of buying one of the aftermarket tracking devices myself, but now I figure, "why bother ??" Now I carry the little 11" laptop with me in my back pack in case the same thing happens again - I can get the quad's exact location on the spot.
    This is apparently fairly common with Yuneecs. Mine has briefly - up to 20 seconds - failed to answer controls several times but that's been the only crash. So far....and I'm paranoid now. I've read of many similar experiences on the forum.
  9. Cranky Trapper
    Manitoba Canada
    Holy crap! Now I'm paranoid!
  10. Gogittum
    You're about to get more so. 2 weeks ago I flew my Q500+ from my semi-rural front yard. After a fairly long flight I was out about 1400 ft and started it home. Then low battery warning went off and vibrated the ST10+ and blocked my screen. (Yuneec needs to modify that - how can you fly it home if you can't see it and can't see the screen ??) It got quite a bit further, then gave the heavy warning that battery was low and land immediately.
    At that point things got pretty messed up and got fast changing screens warning about battery, GPS lock and video lock. I was very stressed at that point, too. Still showed video and it was moving, but distance readout remained at 716 ft. No controller input had any effect, including RTH. It had been out of sight against a brushy hillside and I stood there, frustrated and anxious.
    After it became obvious that it was gone, I came in house and connected the ST10+ to my confuser and opened the telemetry. Last known GPS readout showed a location on a hillside in the gully NE of my house. Couldn't read the avc file from camera. I went there and covered a large area bush by bush and grass clump by grass clump, being sure to look in the tops of the very dense, tangled, 10 ft high Mountain Oak bushes.
    I then zigzagged a swath 100 yds wide all the way home with no joy. Gone.
    Then read the instruction on the forum to change the suffix of the avc file to mts. (can't remember the name of the poster, but thank you Very Much) Wonder of wonders, it worked, but video cut out abruptly at about the point I started it home and about 300 ft short of where GPS said it went down. Oh well, good try, but still gone.
    That was Thurs. The following Tues I got a call from the police dept. A lady had found my drone in a corner of her yard, took it to police and they read my name and phone # from the plastic label I'd put on it. I went down there and retrieved it with many thanks to them and the honest lady. Her home is just over ½ mile NW of the last reported GPS location. It flew that distance on a supposedly pooped out battery. ?????
    Video card in CG02+ showed the flight all the way to the crash. ????? It also showed that my control inputs of turning with left stick worked and tilting camera worked, but nothing else. It flew a steady, arrow straight descent to her yard. It barely cleared a busy road at about 6 or 8 ft elevation and crashed beside a rock wall, breaking just 1 prop. It's a miracle it didn't hit a car and/or cause a lawsuit.
    This is my 1st actual flyaway, my 2nd crash due to unresponsive controls and 4th or 5th temporary pause in flight (up to ~20 seconds) with unresponsive controls. All but this last one were with plenty of battery and showing good lock on GPS and video. Since I've only made about ~15 or 20 flights total since owning it, this doesn't inspire me with huge confidence in the thing.
    I do have the ST101 mod from CD and am trying to find out what mods to make to the drone itself (and CG02+ camera) for better range. The ST101 ~doubled (??) my range from ~600 - 800 ft to about ~1400 ft, but it's unreliable over 1000 ft. Jafo and others are getting 4000 ft+ range, apparently reliably. I'd sure like to see that for some of the video projects I have in mind.
  11. Jafo
  12. Jafo
    Getting better with these Video Conversions :)
    Cranky Trapper likes this.
  13. Cranky Trapper
    Manitoba Canada
    Ya gotta kinda wonder .... with the bird acting the way it does.... perhaps warranty to get a new one?
  14. Gogittum
    Good thought but not too likely. I bought it used from a friend (??) and am apparently the 3rd owner. Don't know if I dare sell it or not. :-(
  15. Gogittum
    Thanks, Jafo. Hate to appear dense, but a couple of questions: 1) From the connector shown under the cut plastic inside the Q500+ there is already a wire with a lump on it going down a landing gear leg and taped to that leg. Does that qualify as an external antenna ?? Man, (snivel, snivel) I sure hate to pull all those screws again if I can avoid it. If not, possibly I could cut that wire and splice the new antenna into it ??
    2) Looks like the CG02+ mod puts the antenna dangling from the belly of the Q500+. I've already flown it with the black lens cover piece removed and the antenna dangling out in space. (this was before getting the new controller and before doing the ST101 mod) Wouldn't this accomplish the same thing without the extra connections and cable length ??
  16. Cranky Trapper
    Manitoba Canada
    Ah crappy!
