  1. EnlightenOnQ
    QUESTION: Is there a manual flight mode on the "H"? I've noticed in a lot of the video's the landings are a little harsh due to the mode used to control altitude (seems to be a loiter mode only). I'm used to the 3DR Pixhawk on my Steadidrone and use Stabilize mode to take off/land because this give me precise control of the throttle/altitude of the drone. Auto landings are nice but when you get a cross breeze and the ground effect kicks up your gonna pound it in when you loose that air under your drone.
  2. yufasa
    When in "Angle" mode you have more control and as soon as the landing gear touch the props go to idle. I have no problems landing my Q500 in this mode.
    In this mode you steer by the direction the frame is pointing so you have to keep track of the direction the drone is pointing
