  1. RiverRunner
    Here is a short clip showing a simple use of the cruise control to pan the aircraft while automatically yawing the camera.
    Brandon B and Mike_Flys like this.
  2. RiverRunner
    A similar action but with manual increase of altitude.
    Mike_Flys likes this.
  3. Old Jar Head
    Looks cool.
  4. BillyTexas
    I like that.
    Bill W.
  5. RiverRunner
    Another automatic yaw and pan.
  6. abinder
    When you say "automatically yawing the camera", do you mean the Typhoon H yaws the camera/gimbal without you doing anything while you are using the right pad as a 'cruise control' ?
  7. RiverRunner
    Yes. I rotated the gimbal yaw knob to the right a bit, tapped the trim pad a few times to start the H flying forward and then flip the gimbal switch to global. The H flies and pans the camera automatically with hands off.
  8. abinder
    Okay. Now I see what you meant.
  9. Brandon B
    love it...I want to do the upgrade for this reason alone...but the loss of range and compass issue has me on the side lines... :(
  10. David Armstrong
    Very nice!
  11. glider
    Can you combine change in altitude, flyby and pan/yaw at the same time?
  12. abinder
    I believe that you would have to manually control the altitude with the throttle stick or use the CCC mode.
