  1. OnTheRopes
    Peak District, UK
    Booted up the ST16 and connect RC
    However I cannot get it to connect to the CGO3P?
    have selected the CGO3P under Camara select in the menu
    I then go into Bind in the menu, the a/c is already bound. I select the camera and hit the Bind button.
    I am asked for a password which according to the manual is 1234567890 which I enter and press OK.
    The screen then says Connecting to flight sim
    But every time I get a connection failed eason: Unable to connect to camera Please retry ??
    I am a bit lost now
  2. JCFlippen
    Cardiff-Wales UK
    Sometimes it takes ages to connect you may have to be extra patient. Are you doing itn a wifi environment where other sources are confusing things?
  3. OnTheRopes
    Peak District, UK
    Thanks for your reply, I was trying to do it indoors. Took it outside and it has now connected.
    Cheers
    RiverRunner likes this.
