HELP IN SETTING UP HITEC X2 AC PLUS CHARGER
New Jersey and New Hampshire
Hi people, I am a new pilot and very green. But am very hooked on flying. My husband is the same except he is not an internet person so I do it all. I bought this charger from Frank at Carolina D
And I do not know a thing about charging . I have a Q500S and 4 batteries. All Was fine until I opened the box and then immediately closed it. There's a lot of wires and it looks scary. I want to know how to charge and to discharge. Is there a set of instructions that talks to a beginner? "Charging for Dummies 101" Something like
Plug Wire A into hole B then wire B into hole C on the other side. You know what I mean? Then I need to know how to read or set it. So wondering if there is a You tube or a tutorial on this product. It seem quite popular. I went with recommendations from in here. Any help would be appreciated
Here is another Hitec x2 video. I use one of these. Only get 3.2 amps on each channel when using AC power for H batteries but this is enough.
Here is the Q500 charger that's supplied with the Q500 that's if you have the Yuneec standard charger.
Jesster0430
