I don't want to have my micro sd card eaten by the ST16 controller. If the ST16 is positioned so it is laying on a table with the monitor facing up, which side of the micro SD card is up?
I looked at the little picture on the front of the ST16 and if you look close it shows the little tab on the left side, so that I took as the gold connections
UP. I have put it in and taken it out several times with no problem. Push in till it locks and it will be even with the case. Push again
with your finger nail, then it should pop out just a little. Hope you get it working..
