  1. pinodrone
    Hello.
    After updates the engines do not light
    The button of ignition Start does not work
    I installed updates Americans and not the European ones
    How can I fix the problem
    Thanks so much.
  2. Rayray
    Rayray Moderator
    Staff Member
    Pine Forests of Deep East Texas
    Rebind the units.
  3. pinodrone
    already done does not work
  4. Brian Mackey
    Eagle Idaho
    Do you live in the USA? If Not I would try and install the correct updates.
  5. pinodrone
    [Quote = "pinodrone, Posta: 41711, Membro: 4363"] GiĆ  Fatto [/ quote]
    [Quote = "Brian Mackey, posta: 41713, membro: 4105"] Non si vive negli Stati Uniti? Se non vorrei provare e installare gli aggiornamenti corretti. [/ Quote]
    the correct updates will not let me install it gives me error
    I live in Italy
  6. THoff
    What does not work? The rebinding, or arming the motors? Did you update both the ST16 and the Typhoon H with the American firmware, or only one of the two?
  7. pinodrone
    [Quote = "THoff, posta: 41718, membro: 3205"] Che cosa non funziona? La rilegatura, o armare i motori? Forse si aggiorna SIA L'ST16 e il Typhoon H con il firmware americano, dei O Solo Uno Due? [/ Citazione]
    arming the motors , only one of the two, Firmware Typhoon H
    Typhoon H firmware and America AND NOT LEAVE ME THE EUROPEAN UPDATE
    #7 pinodrone, Aug 16, 2016
  8. pinodrone
    IS THERE A METHOD TO BRING TO FACTORY SETTINGS
  9. Brian Mackey
    Eagle Idaho
    there are two updates you have to do, one for the Typhhon H and then one for the St16 sounds like you only did one
  10. pinodrone
    by mistake I updated the Firmware Typhoon H AMERICAN and now will not let me update the Firmware European Typhoon H
  11. Brian Mackey
    Eagle Idaho
    OH Okay --- I cannot find a factory reset, maybe a call to Yuneec?
    pinodrone likes this.
  12. pinodrone
    in Italy there is no assistance yuneec , and do not speak English, thanks
  13. Brian Mackey
    Eagle Idaho
    Let me see if I can reach them...
  14. Brian Mackey
    Eagle Idaho
    Okay -- Not good news, unless some guru here knows how to reset the H, Yuneec says it can only be done at the factory! You would send yours to the Germany Location sorry for the bad news!
  15. pinodrone
    ok thanks
  16. THoff
    Before sending it in, I would try to do the firmware update via the Yuneec GUI application. Connect the Typhoon H to a Windows computer using a USB cable, it should then show up in the GUI. From there you can click on Firmware Update and select the American Typhoon H firmware file and upload it to the drone.
    abinder and Brian Mackey like this.
  17. Brian Mackey
    Eagle Idaho
    Great idea!
  18. Gowron
    Pinodrone, you do not need to send it back..
    To reset the st-16 back to factory...
    click on tablet screen
    click on settings
    click backup & restore
    you should find the option to reset your ST-16 back to factory settings.
    once you have done so you will need to rebind the drone and camera also then calibrate the gyro & speed controller.
    the Yunnec uk website and EU software firmware.
    Firmware
