Home made Quick change FPV camera for Goggle use
Maryland
Wanted to be able to switch from my Gopro to a fpv camera & 5.8 TX set up so could use my goggles for flight. Used a Base from a Blade CG02 gimbal. Smaller than Q500 base & uses same mount. Runcam 600TVL camera & Boscam 5.8 TX. A little work with a dremel and light soldering TX fits neatly inside base and can switch from gopro gimbal to FPV setup in about a minute. Everything cost cost under 75$ and works excellent.Setup only weighs 74 grams and is a lot more aerodynamic verses Gopro with gimbal weighs 241 grams fpv 1.JPG fpv 2.JPG
hendrtiz
