I heard rumors that both Chroma and Yuneec are produced in yuneec factory,what is the difference between them?
And the Horizon's battery is 7200mah instead of 6300mah,is the flight time much longer ?
Yuneec produces quite a few different hobby and commercial craft.
You need to specify which models you want to compare.
Batteries? I think the manufacturers' rating do not always indicate the true capacity,
Speaking of batteries, how are your battery sales for the Typhoon H going? Does your battery provide longer flight times compared to the standard TH battery?
I understand,but the true capacity of yuneec battery is 6300mah,and the chroma battery is 7300mah,it is true 1000mah,.because we produced both those two,so just trying to know if the chroma can fly longer because of it.
And about the question you asked about our battery,truth be told,it should be the same flight time compare to the original one,because capacity is the same,but someone tested it 1 min longer,someone said it the same,guess it is about the testing condition difference,not the battery
The yuneec real capacity is 6300mah,but the chroma 's battery capacity is 7300mah,so that is why you can hit 30minsI had a chroma with the CGO2+. Back awhile ago yuneec and horizon hobby struck a deal and that has lead to many blade products from yuneec. The 350qx, glimpse, chroma were all yuneec designed for horizon. On my chroma I could hit 30 mins real flight time. The battery is 6300mah, this is according to my 3rd party hitec charger. Originally it was labeled as 5400mah but the label was changed.
But we follow their datas,our Chroma battery is 7200mah instead of 6300
I don't believe that's possible.
