Has anyone had a problem with the “horizontal tilt” stop working? I have run diagnostics and controls check out but I have no movement from camera. I have tried several different cables and received the same results. I am open to any suggestions.
Try re-binding the camera to the ST16 and then do a gimbal calibration .. have you done the latest updates ??
I have the latest update but have not tried the "re-binding"........yet. I will give that a go and see. Thanks!
don't forget to do a restart after each calibration and after each update ... sometimes it matters and sometimes not ... I do it just to be safe
Thanks for the reminder but I too have found I get much better results with the re-start after a calibration.
rrichesin
