HowTo: Analyze your flightlogs and watch your flights in Google Earth
I'm Lost, most of your title instructions are hidden by tour main Title and can't be read! Also jumped to fast between steps and got lost! Maybe it's just me and my old mind! LOL ! But this is a great idea and very useful tool, just like DJI's Flight Log overlay, I hope you can redo in a easier follow along! As I am grateful for your information!;)
Reactions: yuneec53
You can find all Infos in the Video description too and if its to fast just use pause ;) Hope that helps
Reactions: DroneClone
I'm Lost, I hope you can redo in a easier follow along!
Drone,
-Install Google Earth to your PC.
-Get this tool.
3rd file down on the right side.
Downloads
DIRECT LINK: http://h-elsner.mooo.com/downloads/q500log2kml_en.zip
Unzip the tool/program from the zip archive. The tool/program is called "q500log2kml.exe"
-Copy the telemetry data folder from your ST16 (under flightlogs) to your mSD card. Make sure you eject the SD card properly before you remove the mSD card or turn the ST16 off before you eject it.
Note: I use an OTG cable and put the data onto a normal USB stick.
You can also just use the supplied USB cable you get with the H to connect directly to your PC. You should see the files in a folder, just copy those to a folder on your PC.
-Copy the telemetry folder from the ST16 to to your PC using whatever method you choose.
-Run the "q500log2kml.exe" program.
-In the "q500log2kml.exe" program select folder next to "Flightlog" and point that to the saved telemetry data folder you copied to the PC.
-It will show you a list of your flights on the left. Numbered 00001, 00002 etc...
-Choose the flight on the left you want to view or export.
-Tabs can show you the data, histogram and settings.
-Select the settings tab. Make sure under the Output Files section that KMZ is selected.
-Export to kmz file by pressing SAVE.
It will save a file in the same folder that contains your telemetry files.
(If save is ghosted, select something other than kmz then select kmz again.)
Edit: Actually I think when you hit save it just exports them all out at once.
-Run Google Earth and import the kmz file you want to view.
-->File->Open and select the file.
That is it!
Did that help?
Drone,
-Get this tool.
Downloads
-Download the telemetry data to your PC, put it in a folder.
-Run this tool.
-In the tool select folder next to "Flightlog" and point that to that telemetry data folder.
It will save a file in folder that contains your telemetry files.
-Import the kmz file you want to view into Google Earth.
-->File Open and select the file.
That is it! Did that help?
I'll have to copy this into a Google doc. Great info
I edited it a few time so make sure you get the latest version. i:)i
Just trying to help. i:)i
Or just do a rightclick on the kml File in your explorer and choose 'open with Google Earth'
Absolutely! You can set your PC to always open .kmz filetypes in GE as well.
I didn't want to get overlay complicated. i:)i
Drone,
-Get this tool.
Downloads
-Copy the telemetry data folder from your ST16 to your mSD card. Make sure you eject the SD card properly before you remove the mSD card or turn the ST16 off before you eject it.
-Copy the telemetry folder to your PC.
-Run this tool.
-In the tool select folder next to "Flightlog" and point that to the saved telemetry data folder on the PC.
That is it!
Did that help?
Thanks Paladin! To download Telemetry file to PC, can I just run a usb from 16 to PC? I hear the sd card drops into the 16 sometimes/ And thus never put it in, I have seen the files so don't see why not? Thanks!
Absolutely! Any way that works for you to get the files to the PC is the way to do it. i:)i
I added it to my post.
Drone,
-Get this tool.
Downloads
-Run this tool.
That is it!
Did that help?
"Run this toll" above, you mean the downloaded Zip file in step
Drone,
-Get this tool.
Downloads
-Run this tool.
That is it!
Did that help?
What do you mean"Run this File" ? The zip file in step 1 ? Thx's
Yes you have to unzip the tool/program from the zip file, that is kind of obvious I thought. i:)i
I will add that step as well then. i:)i
Or make it easy on yourself and just upload the telemetry file to exmaps.com.
Paladin, absolutely brilliant, thank you!:)
Works a treat!
You wouldn't add an explanation of the colour codes for the Display Files display to the manual, e.g. pink and red under Date/Time, please?
All credit goes to lordbrummi and the original video that he posted.
I don't know much more than you do, I just walked through the process then wrote the directions that I did. i:)i
However there is a manual for that program here:
http://h-elsner.mooo.com/mydat/Q500log2kml_en.pdf
According to that on page 4 it says:
"In column Date/Time cells will be marked with color, if the interval between the time stamps is bigger than expected. This may be normal, but it indicates possibly bad radio conditions or high processor load in flight controller. Good to have an eye on it. Threshold 1: salmon - 600 ms Threshold 2: red - 2 sec"
Then thanks to lordbrummi and yourself!
I looked at early telemetry files and found where my H was assembled and flown in China, then Germany.:)
lahorelaptop
