I think that all were at one time, as I have files from China
I have one as far back as 12/2015, must have bought the one they used at the CES I LOLI can just picture 100 Typhoon H's all being flow by 100 guys at the same time. Look like a flock of birds..
HEHE No idea why I pictured that.
BTW what are the dates you guys are seeing for those tests? Just the range, I don't need a list. ii
I seem to have 4 of them and my earliest seems to be 05/08/2016.. Weird they did not clear those.
Paladin, I meant at sometime or another, not all at one time! LOL !
I have 6 from China , two from Cali and the rest are mine! all mine! Heee Heee HeeeYes but it is funnier my way. ii
So how many do you have total that have data? Just curious.
I just noticed that when you hit save in that program it exports all the kmz files at once.
Not me! The H is precious!Your precious!
By the way Paladin, can you redo your instruction on a step by step viseo like the one above, just for us ole'farts! LOL !
Come on! your on this forum as much as me, which is always!(And that's okay!) You've got tons of time!!! LOL ! Thanks, I do understand and have done it already! I do also appreciate the time you did spend in making it available to us all too !I did actually see that one. Never really hurts to repost. Hard to keep up on everything.
Pretty much already step by step man. ii
Video requires a lot more work, screen shots, adding graphics etc.. I just don't have the time right now.
My Antivirus is blocking the download, see photo attached...Drone,
-Install Google Earth to your PC.
-Get this tool.
3rd file down on the right side.
Downloads
DIRECT LINK: http://h-elsner.mooo.com/downloads/q500log2kml_en.zip
Unzip the tool/program from the zip archive. The tool/program is called "q500log2kml.exe"
-Copy the telemetry data folder from your ST16 (under flightlogs) to your mSD card. Make sure you eject the SD card properly before you remove the mSD card or turn the ST16 off before you eject it.
Note: I use an OTG cable and put the data onto a normal USB stick.
You can also just use the supplied USB cable you get with the H to connect directly to your PC. You should see the files in a folder, just copy those to a folder on your PC.
-Copy the telemetry folder from the ST16 to to your PC using whatever method you choose.
-Run the "q500log2kml.exe" program.
-In the "q500log2kml.exe" program select folder next to "Flightlog" and point that to the saved telemetry data folder you copied to the PC.
-It will show you a list of your flights on the left. Numbered 00001, 00002 etc...
-Choose the flight on the left you want to view or export.
-Tabs can show you the data, histogram and settings.
-Select the settings tab. Make sure under the Output Files section that KMZ is selected.
-Export to kmz file by pressing SAVE.
It will save a file in the same folder that contains your telemetry files.
(If save is ghosted, select something other than kmz then select kmz again.)
Edit: Actually I think when you hit save it just exports them all out at once.
-Run Google Earth and import the kmz file you want to view.
-->File->Open and select the file.
That is it!
Did that help?
Just so you know, I got the following threat message from my antivirus once i had all the files
You might want to check the pdf file as this may be why somebodys blacklisted the domain...View attachment 13410
Program works awesomely! Love it! Thanks for this!
