Sensor is safe from the glue UNLESS the lens is totally removed from its base.
Few ways to deal with the lens glue when removing it but an easier way is to run a vacuum cleaner as you cut it away to suck the loose **** off.
To adjust the lens to suit your needs, the best way is to connect HDMI to a big screen and watch the screen as you turn the lens. Even better way is to find a focus templet and print it on an A4 sheet, place it whatever distance you like and watching the big screen...turn the lens until the template looks clean on the big screen. Very easy process. BUT BE CAREFUL AND TAKE UR TIME stripping the camera body. A sharp razor blade works perfectly to remove the Glue.
Once u find ur focus point, u can run some glue where the old glue was to stop the lens from vibrating out of focus OR if ur keen enough, unscrew the lens completely and run 1 tickness of thread tape around the lens thread, that will keep it secure and be enough for u to adjust it for ur focus point by hand.
Another tip is to mark the focus point so that in future if u need to do work in there again, u will know where the focus point is when the line u drew lines back up
