- Joined
- Feb 4, 2017
- Messages
- 24
- Reaction score
- 3
- Age
- 50
Great. Glad to hear that. See if you can get the H to boot up with the battery.Did it the same way I have done it 3 dozen times before. Push it all the way in until click.
Try putting the battery back in and see if you hear it click. Then try to remove it without lifting the lever on the battery to see if it feels like it's locked in.
Ah. Ok. It's hard to see the damage in the picture.I know that won't work because the end of the battery and that side of the bird is smashed and the clip that holds it in is broken.
I'll be interested to see if Yuneec take care of you with this problem using a non Yuneec battery.
Interesting point about the battery brand.
Yet another reason to keep with the original (Yuneec branded) stuff - possibly?
Will do tomorrow. Time for bed right now. Thanks again.
Don't know if it matters to them, but this battery was made specifically for the H. Or at least the label says so. It did actually give me a good 3-5 min extra flight time than the Yuneec batteries. Might have been the 5th time I used it.
For the previous times you were using this battery, did it ever give you a low battery warning while you were flying?
Only when voltage hits 14.3.
Not to say this could have been the problem, but 14.3v equates to 3.57v per cell.
Maybe the batteries you were using don't react too well in regards to being dropped down so low?
It would be interesting to get other members opinions on these batteries to see just how well they do hold up. Given you have only used these for 5 cycles, I would doubt that this was a contributing factor.
