Important FIRMWARE version B23 - List Known Issues Here
After updating your H did you have any problems?
  • Flies great. No problems
    Votes: 67 60.9%
  • Compass errors
    Votes: 28 25.5%
  • GPS errors
    Votes: 18 16.4%
  • Loss of control. H won't respond to controller
    Votes: 16 14.5%
  • H flew away and crashed
    Votes: 13 11.8%
  • Total voters
    110
  • Poll closed .
John, the column name you are looking for is the 2nd to the last column called error_flags_1. If you click on the column heading name error_flags_1, a new dialog box pops up called Statistics for error_flags_1. All of the errors if there are any in the telemetry data will be displayed. If there are no error 32's then there are no compass calibration warnings. Keep in mind all of your flights are displayed in the left most column, 00001, 00002, etc. As you click through your flights on the left the display file data including error_flags_1 will be updated. On mine, flights 00001 to 00010 were from Yuneec. My flights began with 00011 with the highest number being your most recent flight.
Greg
Thanks for your response Greg. I opened them in Excel, it does not work there. Are you using a program to view with?
ALso, I am seeing feedback from several other sites.locations, other pilots are having great success with today's update.
Ah, yes I am and assumed you were as well. Below is from my earlier post #235
It's called q500log2kml and its awesome. It only works in Windows but I was able to use Winebottler and make it work on a Mac. Most of what you will find for it is in German but there is an English version as well. It was designed for the Q500 but also works with the Chroma and Typhoon H, no problems. Documentation is either in the .ZIP file or available from a link in the app in .PDF for either English or German.
http://h-elsner.mooo.com/downloads/q500log2kml_en.zip - English link
http://h-elsner.mooo.com/downloads/q500log2kml.zip - German link
Greg,
Thanks, I downloaded the program. Works great. The only errors or warning I received after three flight was a Low Battery Warning.
Hope you have the same success. Happy Flying!
John
Hello All,
I am having trouble arming the copter and the start/stop button stopped working after successful firmware update to b23. Now I know a lot of people have had the same problem. some could get it going by adjusting the channel parameter and some by reseting the ST16 to factory setting. I have not been able to resolve the matter by following the methods have been told by others.
I am going to point out to some factors and then it would be great if some one hands out his experience and knowledge on this matter.
1- The ready light indicator on ST16 screen is in blue. when I push the red button it makes some beeps but no start. However I am not sure if the Hexa Icon on top of the READY status should be in any color or not. right now is dimmed and greyed out.
2- I have telemetry reading and GPS OFF IN angle mode.
3- Camera is working and everything seems ok.
4- When I push red button the out put monitor shows its working and going from 50 to 0 once its hold.
I have gathered some pics of my channel setting, Firmware info page and so on... thank you all in advance
Hello
when you try to install the new firmware, there was a glitch in the machine Tufoon X Next, after the power button is not being installed their own firmware and the device does not turn on completely, LEDs do not burn, rear indicator lights faint blue. The firmware on Article 16 established correctly.
After the initialization is complete, the firmware, it was reported for restart. But the shutdown button does not respond the energy, off occurred only when the battery is disconnected !!!!
that I need to take to restore the system?
typhonn H Pro
ST16_V3.1.25.yuneec
TyphoonH_Ver3.0_A
mathewthomasmt
