- Joined
- Aug 2, 2016
- Messages
- 126
- Reaction score
- 53
Ascending tone and green light before reboot.What feedback confirms that the compass calibration was successful?
No, just turn on the ST16 the H does not need to be powered up, on the settings - hardware monitor just look for any flickering of the green bars. They should be steady at zero, try moving and letting go the sticks and they should always return to zero and stay there.Not familiar with this. While the H is flying?
There is a light sequence of the status leds and finally a reboot of the H. If it ends in a white light I believe it has failed and should be done again. I have tried fast turns, slow turns, pause between rotations to see if lights stop flashing, what I found what works for me is two complete turns keeping the axis of rotation as true as possible then keep the H as flat as possible when changing to the next axis/ arm set.
Yes,I 've noticed too ,that the RTH brings the H back at full speedI've noticed that the RTH brings the H back at full speed ie 45kph, I think before it was set at about 25kph, I believed that the 25kph speed was the most efficient for distance v power, this seems to have changed.
Hi,
It would appear that on a 16min flight I had two issues,
Code 1 which I think is the low battery warning at the end so no problems as it worked fine with 20% left in the battery
Code 32 compass calibration for about 1 second.
I have loaded the Telemetry files into Exmaps and it shows a movement of the H into the next field which didn't take place? No warning vibration or otherwise came onto the transmitter.
Can anyone with more info on reading these files have a look and check out if anything's badly out of wack?
After the 13 September update,(even the 1 September also no problem at all) I calibrated the compass before the flight everything is perfect, the only thing is when you switch to RTH it fly back with very high speedI just got my 3rd replacement. It shipped with the B23 firmware, but autopilot 1.26. gimbal 1.22 and camera 3.2.13(a) and Realsense v 1.1 (The Sept 01, 2016 software platform)
With that code, the same compass errors and GPS lost errors were appearing on the screen and when you moved the TH, it would generate Compass errors, just like the one I sent back last friday.
I didn't bother to fly it this way as I think we know how that story ends.
I updated to the new TH Software from the Sept 13th code with Auto Pilot 1.27 and the GPS and Compass errors stopped appearing at random. I picked up the drone to relocate it and the compass errors are not triggered either.
Basically, all the error conditions of the Sept 1 software on my first 30 min (without flight) seem to have been resolved. I am still very skeptical, but its too dark to fly tonight. I will try it Friday after work after a few more tests. I have not done a compass calibration yet (I will before I fly as thats why Yunnec insisted I do when I got it).
I'm shocked that the persistent repeating errors went away with the Sept 13 code. the drone barley gave me enough time to click the Systems Systems to update this firmware thats how bad it was... so this is impressive it not doing these errors at all anymore (pre flight) now.
I'm hanging in still, hopefully this works....
As a side note, a guy at Yuneec today for the first time admitted there were seeing problems in some units that they could not explain, and THIS is why they are swapping out units so easy, as they want to get those units in the shop for review. I had to pinch myself as I could not believe he confirmed there was issues and why the quick swap process...
For the HIs there anyone that has the 13 Sep update (US version) that would be willing to send it my way so I could install it and test? Would greatly appreciate it.
Hi Greg many thanks for that explination.
The firmware I have is the latest EU varient downloaded yesteray I checked after update and the Autopilot was changed to 1.27 if I recall.
I was trying out all the modes possible inculding RTH and everything seemed ok and 'locked in' and I agree a 1 second glitch in 17 mins should be nothihg to worry about, I wonder if the glitch happened the same time as a retract move, I lost video on a previous flight that day just after take off and the camera would not reconnect. If so I wonder if the retracts are somehow causing a voltage spike or drop, only a thourght!
So its sounding like this latest update (13/14 Sept) has helped with the elimination or reduction of Compass errors which should in turn mean less chances of drifting/TB'ing maybe even less chance of fly-aways...
The cynic in me wonders if they just added some code to suppress the frequency of this error being reported.... Of course I'm hoping its the latter... Might be worth upgrading then...
Ha, that cynical thought was in the back of my mind also especially given Yuneec's track record of late but I think we all need to take a step back to see just how big or small this firmware issue really is. I know a lot of users here have had issues but in the frame of total unit sales how big is the issue really? For the individual its really big but as a whole? I don't know that we'll ever really know.So its sounding like this latest update (13/14 Sept) has helped with the elimination or reduction of Compass errors which should in turn mean less chances of drifting/TB'ing maybe even less chance of fly-aways...
And you have the latest firmware also, or the 9/1? version?Good idea but, for me, I get some 32 errors during some secondes ....... excatelly during flight mode 21 = Smart mode - Follow me...........
