Yes. Yuneec sent me the "no alt limit" firmware.The last firmware update was Jan 1st of last year. Are you sure it needs updated?
I would guess it's the same method used on the H. If you put a micro sd card in the ST24 and go to the update menu it will probably tell you if it does or does not see the update firmware. However, it's best to give Yuneec a call and ask them.Yes. Yuneec sent me the "no alt limit" firmware.
I bought the copter in December. It had a defect that made it appear to be unbound. Sent it to Yuneec got the copter back in January. 2 floghts thus far. I favor my Q500+ over the H920.
I will hold off on the firmware upgrade for now. I actually plan to send the copter back.
I would like to know the procedure to update.
Sent from my SM-G930T1 using Tapatalk
Getting Yuneec to provide information is difficult. I am over the H920 and lack of info.I would guess it's the same method used on the H. If you put a micro sd card in the ST24 and go to the update menu it will probably tell you if it does or does not see the update firmware. However, it's best to give Yuneec a call and ask them.
