Itelite antenna
Discussion in 'Q500 4K Help' started by mark walter, Feb 1, 2016.
  1. mark walter
    I recently upgraded my wi fi antenna to an itelite. It's supposed to double if not triple my distance and improve video quality. I have seen no improvement. Was wondering if I need to so a software update to the camer, controller, or typhoon or all 3. All the reviews were excellent for the itelite.
  2. Chris K.
    I had the same problem. You do not need to do an update. You need to make sure your 5.8 wire is not touching the GPS wires. Basically you can't run the wire through the same routing the stock wire was. If you run it on either side of the of the GPS modual. After I had spoken with Carolina Drones about the same issue I re-routed the wire and I have seen a significant improvement.
  3. mark walter
    Thanks a lot. Just didn't make sence. All the reviews were great. Thanks again. I'll let u no if that worked.
  4. mark walter
    Is there anyway to upgrade the GPS antenna?
  5. Ed Hahn
    I have the same problem I did not get any more distance
    Frank from Carolina is looking at this for me. I'll let you know
    what happens
  6. mark walter
    I was told if the 5.8 wire is touching the wifI wire it won't work right. I rerouted the wire and I still don't see much of an improvement.
  7. mark walter
    Heard nothing but great reviews about this antenna. Easy install I made sure the wifi wire is not touching the other wires and I still can't take it out further than 1500 ft without losing wifi. Not only am I losing wifi I'm losing gps also. Getting scary. Lost signal at 600 ft. Earlier today. Original setup worked a lot better. I have had to do something wrong as I hear nothing but GREAT reviews. Need help
  8. mark walter
    I made sure the wire wasn't touching and calibrated it and honestly it's getting worse. I'm losing gps signal everytime I loose wifi now. Lost wifi at 600 ft earlier today. Not sure what to do. Might send it to Carolina dronz. They said they would look at it.
  9. Ed Hahn
    I got my antenna back,I am still only getting around 1000 ft.
  10. mark walter
    Your original antenna or the itelite antenna
  11. Ed Hahn
    the itelite antenna. I am thinking of taking it off and going back to the
    original so I can fit the radio back in the case
  12. mark walter
    Carolina dronz called back. They said my WiFi wire connector was bad. They were supposed to take it out for a flight today weather permitting. Hope that does the trick.
  13. Ed Hahn
    I don't think you did anything wrong.I have the same problem.
    It does not work any better then the original set up.
  14. Ed Hahn
    Good luck.let me know if it works.
  15. mark walter
    Carolina dronz said I had a bad wifi connector. Still waiting back to here how it flies.
  16. Ed Hahn
    If anyone is interested in one of these let me know I went back to the
    original set up.Just did not work for me.
  17. Yuneecdion
    What color and how much?
  18. Ed Hahn
    Black,$75.
  19. Ed Hahn
