Sometimes they stick. Flick the stick a few times all around before you enter calibration, then go back and try.Hello guys,
I need some advice as i was doing calibration there is 1 channel J3 did not go green as it should be. What i need to do.? Totally blank here.
What does J3 look like when you check it in harware monitor? Does it return to zero when centered and show full scale when moved both directions?Hello guys,
