  1. gregreh
    Trying to collate information spread across numerous threads
    Changes:
    • Ability to playback video and photos on ST16
    • Task functions can now be used without enabling advanced mode
    • Ability to enable Realsense module if installed
    • Improved wifi/video connection times
    • GPS can be turned off in flight
    • ST16 battery percentage now shown in top right corner
    • Greater EXIF data including GPS coords in photos
    • New flightlog app in 'pad'
    • Format camera SD card from ST16
    • Improved 1080p 120fps video
    Anyone noticed any others?
    All in all I think that is quite a significant update. I'm pleased. Lets hope there is more to come!
    #1 gregreh, Jul 19, 2016
    Skypicswa and David Wilson like this.
  2. Eric
    you can add
    • boot with video screen faster
    • 1920x1080/120fps video improved
  3. Goh
    Goh
    The battery percentage is not the H percentage, is the ST16 percentage
    and no RTH height setting
  4. gregreh
    Thanks Eric. I hadnt checked the 120fps video - good find
  5. Samuel Fowler
    Chicago
    Does anyone have any footage of this 1920x1080/120fps video improvement after the firmware update?? I would like to see the change in this from the old to the new.
  6. Samuel Fowler
    Chicago
    I wish they had a percentage on the battery instead of this voltage amount. Most drones say %50, %30, or even %25 and then you know its time to come home. I am not a fan of the voltage amount.
  7. fux
    fux
    Germany
    They scaled the GUI on the ST16. The GUI was slightly smaller before. Sadly this is not an improvement for me.
    gregreh likes this.
  8. banned user
    At least they are not giving it in US or UK imperial measurements, 153/198, 839/1800, 2987/5876, 20/83
    Samuel Fowler likes this.
  9. Samuel Fowler
    Chicago
    Very true, and I should be happy its not in microvolts. 16.5 = 1.65e+7 :p
    banned user likes this.
  10. THoff
    • The ability to format the memory card in the camera from the ST16
  11. banned user
    Advanced Mode - off, now allows smart routes CCC etc to work.
    What we need is a bug list of things that are now broken.
    Camera connects faster but appears to disconnects more often.
    When the low voltage alarm goes off on the ST16 the 5min video segment being recorded at that moment seems not to get saved to the card. (need to double check but I'm almost sure it's happening).
  12. gregreh
    Second point down :)
  13. gregreh
    Reworded thanks
  14. Markinter
    So Cal
    I haven't flown yet since update but I've read that video lag is less after update but that's unconfirmed Also have you noticed H fits into the case a little better after update?
    Kahuken and Brent D like this.
