- Joined
- Oct 30, 2016
- Messages
- 1,201
- Reaction score
- 439
- Age
- 47
well things started off going great had the first two battery flight no problem the on the third when things went wildly off the rails front left arm flung down still attached to the drone frame sending the drone crashing down hard lost left landing gear the camera well lets see the camera ball came detached from the gimbal bottom cover popped off minor damage the the circuit board confided to one set of wires plug area plug broke off completely still repairable missing the screws that hold the camera ball to the gimble no broken wires amazingly when it hit the ground it bounced up motors spun up and the unit started to go rouge held throttle stick all the way down went for the home switch to kill it the motor switch would not respond had to slam the right stick all the way down magange to hold the drone in one place tring to kill the motors only after I set the home switch to angle the it shut down automatically. looks like the clips failed metal wore out and broke the screws and part tof the metal clip are attached in the effective arms best part I got to rebuild the gimbal mount . and got to get a new lower body it cracked at the modified external antenna area.
