Motor Failure (Red)
Hi, can someone help me what happen with my rear motor on the right side (red light) , i still success bring it down at about 30 feets and catch it with my hand, as i see before it happen after takeoff 6 feets there is a single orange blink..and what is the meaning single orange blink..
Thanks for any helps
I believe you lost compass calibrati.
Maybe the failed motor is affecting the magnetic field that the compass operates in?
Romi it really doesn't take much. My Iwatch affects mine. Fly safe
Are you talking about the led under the motor or the status light under the belly?
@Dragonflyerthom, @THoff @Steve Carr
I check this morning and trying to spin by hand, all motors spin correctly except the B (the red led under the motor) strange the coil inside like it burn , feeling bad at this time..why and why
Sure..already call distributor, but i wonder to know what make it happens? is it the battery problem or another things..i do need to figure it out for my notes later...
Romi it is rare these brushless motors fail. It happens call Yuneec for a RA#. These TH are too new to have this problem.
Will send TH back to dealer asap...let them analyze..thank you all..
drakemerch33
