My home made FPV
Discussion in 'Q500 4K Discussion' started by Roland, Apr 23, 2016.
  1. Roland
    With a little patience and experimentation, my home made FPV is a delight to fly with, it looks primitive but it does the job for me:
    HEADBROS likes this.
  2. Brian Connor
    Maryland
    P1010002.JPG I did a similar setup like the fact can switch back to gopro gimbal in less than a minute. Power from camera connection is regulated pretty well and filtered. I have only had it out to about 500ft but great picture for a home made setup
    HEADBROS and Roland like this.
  3. Roland
    Nice...Less cluttered than my build. Glad to see you were able to fit all the components in one layer housing.
  4. Brian Connor
    Maryland
    Thanks, whole setup only 76g I just build one for my buddys Q500 with smaller 700tvl camera mounted to front of gimbal base
  5. AveryBadman96
    I don't understand why you just didn't use Q500 4k camera? If it was a distance issue there are mods for that, probably a lot cheaper than your setup. That doesn't look like a high resolution camera either?????? Why?????
